Sileighty's Man »
https://forums.nicoclub.com/sileighty-s-man-u55916.html
Fri Feb 01, 2008 4:56 pm
There's an idle adjustment screw on the throttle body? If so, where is it? I have a high idle problem (1500rpm-1700rpm) and I've changed the IACV (IAA) and everything else corrisponding to a high idle problem. The KA24DE has SR20DET injectors and a 300ZX fuel filter. They were installed from the previous owner and I'm about to ring his head with a friggin' ratchet! Anyway, maybe the idle adjustment screw on the throttle body will help me out with this. I got a Code 34 (knock sensor) too but I highly doubt it'll throw my idle up. Anyway, PLEASE HELP! Thank you!
About the IACV, I don't think you can't toss it. Unless you want my problem then go ahead n' block plate it and see what happends!
