Shusaka »
https://forums.nicoclub.com/shusaka-u119906.html
Sat Sep 26, 2009 8:41 pm
a long time ago, in a galaxy far away...
Ok i just watched episodes 1 through 6 of star wars, it was my day off sorry about the humor, anyways i put some miles on my z finally, i refused to drive it unless it had current registration and insurance. I was fine until dark when i had found out that my pass side headlight was ridiculously dim on low and high beams.
I also happened to notice that on the highway, cruisin 5th gear, 3k on tach, my voltage gauge was pegged at 16-18 i dunno specifically where, but the gauge ends at 16 and was past it, weird right?
I probably need to put this into separate threads, if so lmk mods, but i would appreciate any help on either issue. I'm thinking the alternator has a blown diode, or a voltage regulator issue and needs replaced, but the headlight leaves me fairly stumped, the only thing that i could think would cause that would be excessive resistance in the wiring causing the amount of amperage hitting the light to be significantly lower, resulting in being stupidly dim. i replaced the light but problem still persists, but dr side light is working properly it just wont adjust into drivable specs. Anybody else had these issues? any $.02 would help thanks guys
Randall
