So here's what happens. Before today, I would turn off my car and pull the key out but everything stays on except the engine. All my dash lights, fuel pump etc will not turn off unless I start it and turn it off again. This happened about once every 2 months, so it wasn't a big deal.
After I got my SR in, I've been noticing that it only does it when it's hot outside and/or the engine is hot. It's about 85 degrees here. I was driving on the highway for about 5 miles, and it started hesitating like it wasn't getting fuel. Pulled over, let it idle for a second and it died. So I figured I killed another fuel pump (I've been through 3.) Pulled the key out, and nothing turned off even though I turned off my turbo timer. Sat for about 15 mins to let everything cool off, and it ran fine for another 5 miles. Started bucking when I left an intersection, turned it off and the car stayed on.
It can't be anything with the engine harness because it did this before when I had the KA. All of my grounds on the chassis harness are sanded down and grounded excellently. Could this be a relay that's sticking? Why is it only doing it when it's hot? Any input would be appreciated.
Edit: There's a short somewhere under the dash. When I pull the fuse for my dome light the car turns off. Weird... I hate electrical problems.
