adubon »
https://forums.nicoclub.com/adubon-u67174.html
Tue Feb 02, 2010 12:03 pm
For the past month I have been having problems with my sony headunit and amplifier (powers 2 subs) turning off and on while driving. When I start the car they work, then turn off and randomly turn back on but not for long. Also, the tachometer somewhat stops working as well. The tach will drop directly to zero in between shifting gears, and come back up after it's in gear. For the first time, a couple times today while at a light some of the dash warning lights began flickering and making some noise while at idle.
I replaced the battery with an optima red last week, so I've been thinking it's got to be the alternator. As the z warmed up more and more everything began working better until I had no problems with the stereo or dash lights at all.
I am fairly confused, because if the alternator was bad would it start providing enough power after the car warms up completely?I have not had a chance to check it with a voltmeter yet.
Also there is a slight belt squeal at start up that goes away after the engine heats up. A few months ago the alt belt was squealing very badly so I tightened it to the proper deflection, it was new so I guess it just stretched out, and the squeal went away.
