AndrewKFM »
https://forums.nicoclub.com/andrewkfm-u164317.html
Mon Dec 20, 2010 2:29 pm
So, I've got an 1987 Z31 NA that runs (or did until now), and an 1986 Z31 NA, that crashed and doesn't run, for parts and whatnot.
I went to start the '87 the other day, and it didn't have quite enough juice. Lights would come on, windows and radio worked, etc, but couldn't get enough volts to start the car. It would turn the engine, but not enough.
My battery is only a few months old, and I hope it's not the problem.
I jump started the car, hoped in, turned the light on, and it started to die. I quickly turned them back off, and it jump back to life. I tried the windows, and it started to die. I stopped, and sat there, assuming the problem was my alternator, then the car just died on its own.
One would think alternator, yes?
So, the next day I decide I'll pull the alt from the '86 and put it on the '87, and, just for giggles, I went to try and start the '87. This time I got absolutely nothing. No lights, no tick, nothing.
Do bad alternator commonly draw from the battery? Do I just have a dead short? Do I have a bad alternator and a dead short? What should I be looking to do right now. I don't want to swap the alts unless it's likely the problem, so some guidance would be much appreciated!
Thanks,
Andrew
