ok so here is most of the info on the car, 94 300zx na at, when car was purchased it had an after market stereo(originally had bose system) everything was working properly, ac(auto ac control unit), lights exterior and interior, the only thing that didn't work was the speedo, odometer, and steering was stiff but pump was making noise so didn't think it was a big issue. i haven't done much to this car so far. first thing done to this i put in a little bit of a better stereo, when i dug into that project i found that the wiring behind the hu had been massacred i cut it back to the original wiring coming from harness, once i wired in stereo there were 4 wires not connected and could not figure out what there for. stereo worked but my dash lights didn't as well as my roof light, then noticed my ac panel was dim and only blew out of vents, i can adjust the temp but actual temp doesn't change only hot or cool air. kept looking through wiring to find shorts but nothing, now in the engine compartment fuse box i keep blowing fuses my ignition fuse and my power window i keep replacing fuses $$$$$, while replacing these fuses one day the steering became very easy and hasn't become stiff again
. i keep searching through the fsm but i have no idea were to start some ideas would be great, i can give more info if need just let me know, also i have heard the the time control unit can cause some of these problems but I'm not positive will be checking that out tomorrow
