Postby
jknock »
https://forums.nicoclub.com/jknock-u215063.htmlFri Jan 25, 2013 9:01 am
I have a 95 Nissan P/U i have no running lights or dash lights working, but head lights signal lights and brake lights all work. I checked the fuse box and had a blown fuse, I traced the wiring harness and all looks good any idea of what else i can do.
Postby
PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.htmlFri Jan 25, 2013 7:40 pm
Yeah... does it blow immediately?
I don't really condone this, but if you replace it with a larger fuse, whatever is shorting out should smoke and alert you to where it is
Postby
jknock »
https://forums.nicoclub.com/jknock-u215063.htmlSat Jan 26, 2013 7:45 am
Yes i changes the fuse to the same size 10 amp as soon as i turn on the light switch it pops. Today i will trace all light wires to the harness to see if i can find a bad wire.
