Electrical Gremlins
Maeda
OK so the mechanic's say there something wrong with the "power unit" in my car, so i've concluded that these people are morons and will now fix the car myself even though I don't have the time, but I need some help guys...
The car starts and runs, and will hold a smooth idle. The car can drive around HOWEVER, it feels like its stuck in 3rd or 4th gear. The car will not down shift like an automagic should.
When I start the car the dash will not turn on for about 30 seconds, and then my cluster will light up and my clock will be reset to 1:00.
Car fires up on the first try. The car will shift gears once or twice before reverting into the 'no shift' mode.
I checked my wires but still dumbfounded (which landed it at the mechanics in the first place).
96 S14 KA-TE-manage + Profec E-01Fully charged & checked battery
Help guys! I need to drive!
huguetpj
Car: 93 KAT Coupe
Maeda wrote:When I start the car the dash will not turn on for about 30 seconds, and then my cluster will light up and my clock will be reset to 1:00.
My car did something similar about a week ago. It turned out to be that the alternator fuse was blown. Have you checked all fuses? Both in the driver foot well and on the engine bay?
Maeda
would that explain the transmission not shifting as well?
Structure240sx
did this all start happening at the same time?
Maeda
Yes. Kind of creepy aint it?
Structure240sx
yea i dont knwo about that then
aleph1
Car: 1990 240SX hatch MODS: class.
My friends 1gen DSM auto had a very similar problem with the transmission. He had to rebuild it.
Does it have anything to do with the emanage? have you been running it fine before? might wanna try posting this in the online mechanic section of this forum...
huguetpj
Car: 93 KAT Coupe
Maeda wrote:would that explain the transmission not shifting as well?
Don't really know how autos work so can't be of much help there.
Maeda
it cant be the emanage because I had run this setup for the past 1000 miles.
It's just some goofy thingy that i cant figure out! grr... i'll try the mechanics section..
i posted here in the first place to find out if any other kat -automagics have had this problem...
