Electrical - alternator problem? G50/Q45
bruce.weiland
Car: 2007 Solstice GXP, 94 Q45a, 05 G35 sedan, 01 I30, 01 X5, 95 325i
I searched but did not read through all the pages returned.
I check Q45.org.
Today, after putting in the new NICO ECU I took a test drive. On the way home while sitting at a red light with my left turn signal on I notice the my "traction" light (I always drive with traction control off unless the streets are wet) and my two odometer displays were dimming when the signal turned on.
I turned off the head lights ( my version of daytime running lights) and still thought I saw a little dimming in sync with the turn indicator.
I was idleing at about 600 rpm.
Do I have an alternator problem? I have a VOM. How would I check?
Thanks for the help.
Bruce
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check your battery first with a deep cycle test. Then check your alternator drive belts and pulleys, then the alternator itself.
bruce.weiland
OK. Will do.
The battery is some small cheesy thing the previouse owner put in.
A visual of the belt and everything "looked" OK.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Autozone will do a battery/alternator test for free, and they have an amazing tester to do so.
bruce.weiland
Wes,
Yesterday after I put on the shock tower bar, and put in the NICO ECU, and took my drive I looked under hood one more time to check the belt.
Yep, it was there.
After your suggestion I drove to Autozone and had them check it with their machine.
Alternator was fine and battery was good, but.... I noticed that as he put the negative connection on, the battery clamp moved.
It was, at best, finger tight. The salesman put a crimp on the connector and banged it on good and tight.
No more dimming dash lights.
It sure it great to occasionally get a bargain.
