Elecrical issues buzzing relay
driftsmoke
Car: 1992 240sx frankenstien A/T to M/T harnesses all different auto to manual
Ok i know everyone says do the reasearch but i have looked and spent months and months looking and i can not figure this out. My issue i have a 92 auto 240sx that i swapped a 5 spd twin cam into. Now when i turn the key to the on position and turn it off my Idiot lights (brake,cel,oil,belt) all stay on and i get a buzzing relay from under the hood i belive its the egi.
i have been over all my work its in order i have replaced the dimmer switch and also my ign harness gauge cluster. all together 700 dollars worth of new parts from the dealer in wich i would have bought a dash harness wich im afraid is my next step. i have followed some advice and checked the circut. when it buzzez i can pull the egi fuse and it stops also if i unplug my cluster it also stops. i am completly stumped i need some form of advice for im becoming discouraged with this car and am about to give up.
:wtf2:
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
driftsmoke wrote:Ok i know everyone says do the reasearch but i have looked and spent months and months looking and i can not figure this out. My issue i have a 92 auto 240sx that i swapped a 5 spd twin cam into. Now when i turn the key to the on position and turn it off my Idiot lights (brake,cel,oil,belt) all stay on and i get a buzzing relay from under the hood i belive its the egi.
:wtf2:
Did you replace the relay (shouldn't be buzzing)? ... Also, was the car an automatic before? Did you switch out the ECU?
driftsmoke
Yes the car was an auto i swapped to a 5spd ecu. i have changed the relay still nothing changes i guess what im gonna do is rewire the whole all with 5spd harnesses. is there anywhere to buy them other than the dealer?
gt28rsftw
Car: 89 Nissan 240sx hatch SR20DET
junk yard and go thru and check all the wiring or repin it all. prolly could do it under 200 bucks. or check out wiring specialties. i got my harness ka to sr20 and that only cost me 130 but i drove to his house and dropped it off lol then picked it up 3 days later. His name is Yury and he is awsome when it comes to help about the wiring. he helped me diagnose my no start problem when i did the swap ended up being my ecu and he never once saw my car all thru emails. he knows what he is doing http://wiringspecialties.com/
driftsmoke
Hey man thank you so much i really appreciate everything since your the only one that wants to help on this forum,
if i were swapping the car then i would def hit up that web site but im not so junk yard it is man thanks\.
