nadzak »
https://forums.nicoclub.com/nadzak-u121494.html
Wed Nov 18, 2009 8:12 am
First of all, a 35 series tire will not work. As it is, the 30 series tire is almost an inch taller than the stock setup or a xxx/35/20 setup. So you will definately scrape with a 35/22 setup, especially if you are lowered.Second, it also depends what your offsets are. Even with a 25/22 setup you can end up scratching if your offests are causing the wheels to stick too far out or too deep inside. Be careful and cover all aspects before you drain a lot of money on a 22 inch setup...
