Rickjames8 »
https://forums.nicoclub.com/rickjames8-u259239.html
Sun Mar 27, 2016 8:15 pm
Hello,
So I've finally got my Z running well. I have spent about 40-50 hours working on this car since I bought it, vs 2-3 hours actually driving it. This weekend I cleaned the CAS, and put some dielectric grease on all the connectors and it finally runs ok.
Then the CEL came on. It's a 32 - EGR issues.
I would like to bypass the EGR, but I don't really want to pull the engine or do a plenum pull. To be honest, I've just become so dissapointed with this car. It feels like the list of things will never end, and the next time I have a weekend free to do a job like that is sometime late April.
In the bypass instructions I've read which involve leaving the pieces in the car, they say to remove the tubes going in to the plenum, block them off with the plates, then cut the remaining tubes off as far back as you can, and cap the remainder with a 5/8" cap. I'm doing this on a NA, I understand the TT's can blow those caps off. Now, I can clearly see these EGR tubes on both sides and it looks like I could get to them. It would stand to reason that cutting a 1" section out of each tube (this can be done without a plenum pull) and putting 5/8" caps on both sides would achieve the same thing (both ends are blocked), but without the plenum coming off.
Does this sound like it could work?
-Rick
