Hahahah, add another zero to that end of that. $2500 is the price for a entry level Motec and EFI tech.Pumaking wrote:the most expensive standalone I think goes for almost $2500
Good luck with that.................nightstepper wrote:i called JIM Wolf Tech last week and they said if you send in all the info about the upgrades on your CA they could reflash the ECU for you.
Hehe, Putting SDS and Motec in the same sentence is crazy. SDS is a great system, but there is many reasons why I will never tune a SDS car. Pick the system for you that best suits you.float_6969 wrote:How about $800 for an SDS EM-4? eGhey rulz...
What do M&W Pro-14 go for over there?cortina-mk1 wrote:for motec ppl are paying around $5000 AUD you can pay way more..too
i wonder why? maybe im just defending them because i hear this all the time, and i work there, but you have to understand, when you send your ecu 1000 miles to get tuned, we havnt seen the car, so we offer safe tunes. its insurance so ppl dont get a tuned ecu from us, and then complain to us, or sue us because we tuned thier car too lean and they blew the motor.float_6969 wrote:JWT is infamous for tuning overly rich...
on topic, jwt can do tunes on CA ecus, if you want a tuned map, dif injectors, dif maf, that sorta stuff, we can do it.
I agree with the fact that it's much more wiser to tune a car's ecu that's ump-teen million miles away on the conservative side, but then again, most people send their ecus out to get near peak performance and not mediocrity. I know JWT has done some nice things with the SR series as well as the VG big ballers, but most of these cars are in and around California which is kinda unfair to those who are abroad because Californians and adjacent locals get to bring their cars to JWT's facility and with a little extra $$$s, they can get some good tuning.knightrider wrote:
I ment no insult by this statement, but as you have agreed to, this is a true statement and I thought the original poster should be aware of it. I also understand the reasoning for doing it that way.float_6969 wrote:JWT is infamous for tuning overly rich...
The way SAFC handles add fuel makes it worse. When you add the JWT ECU ($500) SAFC ($300), you can buy megasquirt or a used stand-alone.iliketocrash wrote:this is just my theory but i believe the idea of chipping your ecu is just to get a better base map so you can fine tune it with some sort of piggy back like a safc or somethign to that affect. you can't expect a perfect tune from a new ecu chip alone.
So many of the guys here have spikked their guts with information that should help you make a sound decision. The CA18DET can take a good 30psi of boost on stock motor if it's mechanically up to the task and you have the right ingredients to support such a feat. Run your searched of this forum's archives and run them deep. All the answers to which you seek are somewhere in the archives.fitch9014 wrote:So, essentially standalone engine management is the way to go for big power. I know that I'm going to get links and told to use a search, but the ca18det has how much factory boost, on a what sized factory turbo and a factory computer that can support how much extra boost( safely!), i.e. the fueling needed to keep up with the extra amount of air the turbo is stuffing into the engine(safely!) What I've always wanted is a turbocharged, lightweight rwd car with around 200-250 hp. What do I need to do to get that using stock nissan components? I understand that sometimes you must use bigger injectors with a bigger turbo to get huge power, I also understand that MAFs sometimes get confused but I'd prefer not to get into the more expensive standalone systems simply because if I had the money and no desire to find solutions to power conundrums (or I just wanted to pay someone to do it for me) I would have bought an SR. But I got this engine because so far I've gotten everything I need from napa or the scrapyard. And that's what I wanted a project car that's a true project. In this case a 1.8 liter turbo beater. Thanks for all the info and help.
first off, i used the SAFC as an example. also, the safc does not make things "worse", it does exactly what it's supposed to do for the money you pay, which is less than $300. secondly, i was commenting on the effectiveness of chipping an ECU. i was not comparing the method to using a standalone or anything of the sort. so i really don't know where you're coming from.Coldspawn wrote:
Explain how is changes the fuel via MAP/MAF signal?iliketocrash wrote:also, the safc does not make things "worse",
Great info!iliketocrash wrote:the old afc i know used simple pots and the new safc2 is digital but still works based on the same concept of adjusting the voltages it receives from the mafs/map, that correspond to the user set rpm points and then sends on the modified signal to the ecu. granted it isn't the best system in the world because i know that the safc I made the fuel curve quite jagged because it would just draw a straight line from point to point. i haven't read up much on the new safc2 because i haven't had a whole lot of time for cars at the moment so i'm not sure if they have fixed that problem. i do know that HKS has had a unit out for a while now that has a microprocessor that will actually calculate a smooth curve from point to point so you get a much smoother overall fuel map/curve/whatever but i've heard that the hks unit has some compadibility issues with some cars. however i haven't had much personal experience with it.
