Ecu tuning question?
Coldspawn
Not_a_sr wrote:how much ECU tuning have you been doing with the CA's?
A few. The reason I do not like it is what you are seeing. The data acquisition sucks on it. It is basicly a rom editor and that is it. The only one I see that does it is the bikirom.
You can datalog the MAF off a wideband that will datalog voltage. You can data it and convert the volts into a actual reading.
Not_a_sr wrote:also what about a definition file to use it in tunerpro??
Sorry, I do not understand the question.
