ECU for my 91 VH45DE Q45
Infinitiace1992
Car: 1991 Infiniti Q45t KH1-C Ivory Quartz w/beige interior
Apparently I’m in need of an ECU for my 91 Q45. Does anyone have any idea where or how to get one?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Historically, N/I hasn't put regular Nissan part numbers on very many ECM's. The Nissan part number will almost always be the firmware program stored internally, and of course you can't search that. But there will generally be a manufacturer p/n on the outside of the unit, something along the lines of A56-F44 Z1F or MEC-900 560 B1. Those are what the JY's use to catalog ECM's. Get the numbers off your unit and search eBay or Google, you'll probably get hits.
Infinitiace1992
Thanks for the info
Q451990
ECU failure is VERY rare in that era of Q. How much do you trust the diagnosis?
VStar650CL
Technical Expert
Q451990 wrote:
Fri May 21, 2021 6:48 am
True also. Identifix shows ECU failure being way, way down on the repair frequency list.
Infinitiace1992
Interesting you bring this up. After some thought I'm doubtful this is the issue. I had a jdm engine installed and new injectors from VH Performance and now eng is running rough. No check eng light on and it ran fine before replacing the engine with the jdm engine.
VStar650CL
Technical Expert
Yep, that sounds more like a breathing problem or improper calibration/initialization than a bad ECU.
Infinitiace1992
I'll let him know. Thanks. Any suggestions?
VStar650CL
Technical Expert
One that age, start with making sure the TPS and AAC are set and working properly.
Infinitiace1992
Thank you. I'll let the technician know that.
Q451990
Here's a TSB from Nissan on ECU part numbers for Infiniti up to the 1993 model year. In the real world I think the only concern would be active vs. non active for a 90-93Q.
Q451990
I agree that it's unlikely that the ECU is the issue for your problem. With a full engine replacement, it's a crapshoot where to look first. Leaks, sensors unplugged, damaged wiring harness, the list goes on and on.
