eBay Heads Up: Cusco Flywheel For CA
rico05
Car: 1992 RMS13 w/ CA18DET
http://cgi.ebay.com/ebaymotors...ZWDVW
Damn fine if I do say so myself.
mbmbmb23
Yeah....good find. That seller is a cocky a$$ tho....ever read his auctions thoroughly?
-m
NeedCAforS13
Car: CA swapped S13 coupe
yeah, he's quite a prick. Usually has some pretty nice things though...
Sean
Fenvy
Car: 2005 350Z Base 6MT
and you care because?
are you buying his product or his attitude?
bump for the nice clutch
for those that don't know, his reference of "specialist" is to "jappartsspecialist" on ebay who is a big daddy of jdm parts
mbmbmb23
Loveless wrote:and you care because?
And you care that I care because???
I care because I'm tempted to buy his products but if he's a d1ck like that then you can only guess what type of customer service you'll get if something goes wrong with the order (item is defective or it never arrives). You can tell alot by a seller's comments both in the ad and in feedback. Anyone who has smug, unprofessional comments will most assuridly blame and/or berate the buyer if any problems arise.
Fenvy
mbmbmb23 wrote:And you care that I care because???
right, circular argument, sorry I won't be playing with you
you obviously don't know much about ebay if that's the conclusion you have for the seller
Ghost_silvia
Car: 1991 nissan silvia s13
Too bad we live in TX and have to pay tax
mbmbmb23
Loveless wrote:right, circular argument, sorry I won't be playing with you
Yes, definately a potential circular arguement but since you've yet to post a thought-out point of view I can assume you dont have one or are too lazy to think of one. But....intead of leaving it at that.......I hear that I probably dont understand ebay. Care to expand on that comment as well? I've been on there for 5+ years and have gotten burned a few times.....have you? I've learned to get a feel for who to deal with and who not to. It actually makes me feel good to NOT buy stuff from a$$........more CA parts for you. Bottom line.
themadscientist
guy stands on quite a soapbox there don't he? That is a nice flywheel, Toda doesn't give you the bolts, they tell you to grind donw the stock ones. I learned that the hardway, stripped out the boltholes in the crank That thing is really light though, the car would bog off the launch badly but once it got moving the motor should wind up like a Gixxer!
CA19DET
very tempting, but alas i am outside the USA, but i can still get someone to buy it for me from Louisiana.. hmmm
uno
themadscientist wrote:guy stands on quite a soapbox there don't he? That is a nice flywheel, Toda doesn't give you the bolts, they tell you to grind donw the stock ones. I learned that the hardway, stripped out the boltholes in the crank That thing is really light though, the car would bog off the launch badly but once it got moving the motor should wind up like a Gixxer!
that flywheel plus a lightweight driveshaft and it would be very close to a gixxer haha i think i'll do that sometime soon.
float_6969
I've got that flywheel. And it does bog off the line. Definatly borderlines on not streetable. The motor revs so quicklky though. It's awesome!
biosehnsucht
how long have you had the flywheel on there? just since the rebuild? and how bad is the bog, like can't move the car, slip to 3k rpm to start bog?
alot of cars have lighter flywheels than ours and are 1.8, granted most are NA w/ higher CR..
themadscientist
With my Toda it wa s aproblem on combat launches, as soon as the tires caught traction RPMs would drop like 1500 RPM. normal driving was tollerable after you got used to slipping the clutch a little off the light. I had a DE though, a DET with a twitchy turbo should just be coming on some boost at the crucial moment when the tires hooked.
float_6969
I've only had it on there since the rebuild. Since I don't have the SDS tuned yet, I'm not quite sure. I had it running with the stock ECU, but from what I can tell so far, it's harder to get moving from a stop, but by no means impossible. You've just got to let it slip a little more. I havent' gotten it running well enough to see how it does in a racing type launch.
rico05
I refuse to support that prick myself. There has been several parts of his that I have passed over because of his attitude.
knightrider
Car: black 90 240 coupe
yea i emailed him a while back, about a item, and he is a total prick, i wouldnt buy anything from him.
