YR240 »
https://forums.nicoclub.com/yr240-u59227.html
Mon Oct 29, 2007 4:50 am
I have the finally have the Header installed, the cat-back is on, the XTD Clutch is in, Pain-in-the-everything to do, and we are back on the road. I have not had a chance yet to Open it up but i will say it has a whole lot more forward force than it did. The header gives it much better throttle response and it sounds like a helicopter coming down the road. I got a chance to ride behind to see if it sounded the same way and it does. Over all, I am pleased with this setup. My only concern is the Clutch pedal is very easy to operate. In the past it was rather difficult. I used White Lithium grease on the throw out bearing rider and all the moving Joints, replaced the slave and master cylinder and flushed out the fluid and replaced with Dot5 brake fluid. Now the Clutch feels very similar to the 350z's Stock clutch and my friends celica clutch. Maybe it was very stiff because it was old . Recommendation; pulling the transmission is a 2 person Job! I pulled it on my own with a atv jack, putting it in took some help.
Here are a few more pics
