easy oil change
pfc369
Car: 2007 Versa sl/ cvt
easy oil change from dipstick.
reyes1212
Car: '07 Nissan Versa Super Black
oh what....thats pretty neat. but you still changed the filter right?
feloniousmonk
reyes1212 wrote:oh what....thats pretty neat. but you still changed the filter right?
Yes, you definitely still have to change the filter at regular intervals.
I use the Mityvac 7201 on my bimmer (same engine as the E46 M3). See http://www.amazon.com/Mityvac-...r=8-1
It has a fluid evac mode as well so after you've pumped all the oil out of the car, you can then dispense it from the pump to a container for recycling. Tip: drive the car for 15-20 min, shut it off and pump the oil out while it is hot.
Before someone say changing oil this way is a bad idea because it doesn't drain out any metal particles in the pan, let's use a bit of common sense. The job of the oil filter is to catch these particles. If there are metal particles present in your oil pan, then you have serious engine problems. Extracting oil with a "topsider" is perfectly safe.
Great White Versa
Car: 2007 Nissan Versa S HB 6sp
feloniousmonk wrote:It has a fluid evac mode as well so after you've pumped all the oil out of the car, you can then dispense it from the pump to a container for recycling
How does one go about recycling the old oil? Is there a fee?
randyshemin@comcast.
Car: 1971 240Z, 2001 Sentra SE, 2008 Versa SL, 1999 Mitsubishi Galant GTZ
Most auto parts stores in our area, like AutoZone and Advance, accept used oil.
RetiredTexans
Any Wal-Mart with auto servicing will accept both used oil and batteries. At least they do in the Dallas area. McKinney, TX has a high-efficiency, ecologically friendly proto-type store that burns the used oil their own personnel drain during oil changes as the store's boiler fuel. Oil brought in to them from outside goes into a separate tank for sale. I suppose they make extra $$$ selling it to recyclers as bunker oil.
pfc369
all autoparts store will accept used oil. i took mine to a recycle facilities near my house. they will take old battery and oil filter to. they even accept old water heater and stove. i got my vacuum pump from west marine store for 20$. mighty vac are around 130$.
feloniousmonk
Great White Versa wrote:How does one go about recycling the old oil? Is there a fee?
As others have mentioned, you can take it to the mentioned auto parts stores. You can also:
1. contact your waste disposal company and see if they accept used motor oil2. contact your local city government (some have waste disposal plants that will accept used oil)3. try http://earth911.org/ and use that green search bar at the top of the page
pfc369 wrote:mighty vac are around 130$.
See the amazon.com link I posted. Under $68.
