Hmmm, dozens of 4th generation A/S and 2008 Altima coupes have used aftermarket HID kits on their cars and have found that the headlights on the A/C and 4th gen A/S have a minimal if any glare regarding either oncoming traffic or when following behind someone.swatteamtimmah wrote:Dont waste your time with "Plug and Play" HID kits.http://www.nicoclub.com/articles.php?id=279159
dont be "that guy" rolling around blinding everyone on the streets with your uber bad glare.Do a retrofit, and do it the right way.
-Tim
LongBeachCoupe wrote:Ok Doc... so i went to radioshacks site... the resistors look like its a wire with a small thingie in the middle... Where would this go? I assume that there is going to be a harness that plugs into the bulb... Would i need to cut the wires just before the harness patch the resistor in... then electrical tape the hell out of it?
Or is there a way without cutting?
I actually think this is because the headlights are designed with a cutoff already since the stock xenons don't use a projector. I'm still looking for pics of someone with a 4300-5000k kit from 25 ft away at driver level, though, but I'm guessing it should be pretty good.rjdmmfl1 wrote:
i have driven my wife's Altima Sedan with an aftermarket HID kit, and there was little to no glare.
that would have sucked royallyLongBeachCoupe wrote:The factory Xenon has a different housing... The glare isnt that bad man... i feel like you must have crashed into something because a F-150 had Piaa lights in your face or something and you are angry lol...Regardless of where the light ends... an eyelid keeps it clean!
I think the gentleman earlier was spot on, the factory housing for the base models, while being different than that of the premium package vehicles, have a nice cutoff built into the lens.BlackNWhite wrote:I think Rob said he got the xentec for his wife and I don't think he had problems. That's the one I'm thinking of getting.
I'm doing the same setup as you. I'm putting on those fiberglass eyelids, disconnecting the running light and putting on HIDs. I have the clear turn signals and I have no hyper flash.
No, no I understand your logic! In vehicles that don't have cutoffs built in, placing hID kits into those vehicles would be a nightmare! If you look at the beam pattern of even the base A/C and A/S, they have a pretty nice cutoff, looks almost like a projector cutoff (but not exactly) In any case, whenI pull into my garage in my wife's car, I do notice that the nice cutoff that existed when she had her stock halogens in has somwhat blurred, but not to the point of producing glare. I will take a picture of it and post it to show what I mean!LongBeachCoupe wrote:They eyelids dont go down that far, but as far as a spray is concerned my logic is this... Because its a reflective housing.. that 5000k of light will bounce around the housing and cause glare all around the light.... ergo putting a lid on would cover a portion of the housing that could be producing glare? All BS? i have no idea... just my quick .02
Thank you so much for the pics! This makes me feel a lot better. Cameras tend to look way more glare-y than real life so I think this should be just perfect.generic808 wrote:Pics taken from a crouched position at about 15ft, 25ft, and at an angle, repsectively. Hope this helps. 5000K HID
