e pistons into de.
90ka24de
Car: vRRooommm
Sorry i know this question has been ask a few times but i just wanted to be clear and all so i'll understand... I've looked around here about e pistons going into de's. but nothing much about if it will straight bolt in? any modifications that need to be done to the block other then replacing the gaskets? thanks in advance
TrunkMonkey
Car: 2000 Lincoln Navigator
if you use the oem dished pistons, then they drop right in.
if you use the nissan motorsports flattop pistons, then you will need to mill them down to reduce the compression ratio. otherwise, you'll be trying to run an 11.6:1 compression ratio.
-demetrius
DbD
sorry but i thought putting E pistons into a DE woulkd get you 11:1 pistons anyways right? So I don't think it would be much different running 11.6:1. Just a few more octane right?
TrunkMonkey
your much more prone to detonate by running 11.6:1 compression. the gains over 11.1:1 is so minimal, that it's not worth the risk, or the extra money you'll spend using octane booster or high octane gasoline.
-demetrius
EnzoRWD
Car: 1997 Volvo 850 T5
also, how does one even swap pistons? i was looking at this too, and when the time comes, i hoped i could do it myself <no way in hell will the dealer do this hahaha> Pull the motor? -Enzo
dreamsOfSkylines
I'm about to rebuild my engine and was considering this mod, but I'm still not sure if running 93 octane will be enough to prevent knock with 11:1 compression. Perhaps a adjustabe fuel pressure regulator? Anyone know???
TrunkMonkey
93 octane is enough. you may have to retard your timing.
-demetrius
DbD
Okay time for the real question...Has anyone ever dyno tested their car with stock pistons then with sohc pistons? I am curious as to actually how much horsepower to expect from this swap!
DbD
TrunkMonkey
iirc, you'll gain a 4-5% increase in power for every point in compression that you go up.
-demetrius
s86d
Car: autocross, backroad racing, and working on 240's
ok so has anyone done the mod with sucess even?
TrunkMonkey
s86d wrote:ok so has anyone done the mod with sucess even?
Rownan.
do a search using his name.
-demetrius
