e-manage help
Winona
Car: 1990 240 sx
i just received the e-manage system for my ca18det and i have the ecu pin outs and the e-mange wiring diagram and when it says the airflow input and output with e-manage what pinouts are they talking about because a d air flow pin outs are both on the input sides, please help it would be greatly apreciated
themadscientist
I have to go to work so I don't have time to research it, if it's not answered by tonight when I log back in I'll look it up for you
Winona
Car: 1990 240 sx
ok thanks a lot i really appreciate the help
btustison
It sounds like the same setup as an S-afc... you cut the afm wire and the signal coming from the afm is the input (because it is being input to the piggyback) and the other end of the afm wire will go from the piggyback computer to the ECU making it the output.
float_6969
btustison wrote:It sounds like the same setup as an S-afc... you cut the afm wire and the signal coming from the afm is the input (because it is being input to the piggyback) and the other end of the afm wire will go from the piggyback computer to the ECU making it the output.
You nailed it on the head...
