float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Mon Apr 09, 2012 7:48 pm
Basically, no. That "wire" isn't so much a wire, as a very small tube. The bulb that goes into the radiator has fluid in it that expands and contracts with changes in temperature. The fluid is carried up to the switch where the wires are at and turns the switch on and off. Once the tube is cut, it's ruined.
