Dying my suede?
CaliLalo
Car: !994 300zx
Any products that can clean my suede interior and also can suede be dyed?
BlackWidowZ
Car: Black 93 300zx 2+2
How well do you want to clean it? There is nothing that is going to wave a magic wand and you are going to just like spray it on rub a little and poof.
If you do it like I did I took the door panels and everything that had suede installed on it off the car. Then I used Water and Tuff Stuff. Tuff Stuff is a foam upholstery cleaner you can probably get at local auto parts store maybe even hardware store. I used a Tooth Brush and a bucket of watter and I scrubbed the Suede with Tuff Stuff and a tooth brush and worked out stains as best as I could. I washed all the soap out with water using a Hose outside. let it dry inside. After it dryed I used a dry clean tooth brush to scuff the suede so it didn't look flat.
PS: its not real leather suede. Its a fabric material that looks and feels like it. Thats why Tuff Stuff is appropriate for cleaning it since that's what its designed for.
Best of luck.
