DVD Player On Altima Coupe.
All things Altima Coupe.
theboydiddy
have any of you guys put a GPS/DVD player on the altima coupe? would you mind put some pix ups?i didnt get the gps on the altima coupe because i felt like it was ridiculous to have a screen there JUST for gps and not be able to play DVDs in it. so i was thinking to get an after market one, but idk how it would look since you need to take the whole radio off. i dont want it to look weird.
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
If you get the factory trim plate it will look just like a factory install. Most in-dash DVD players in the car only work when the car is parked/e-brake is on. Before you buy, if this is going to affect you, do some research and find the ones that can be hacked, such as the Pioneer AVIC series.
Pics taken from NissanClub.com
I have the F700BT from Pioneer, it's decent after the hacks but there is better out there...
nogears909
Car: 2008 Niagra Grey Coupe 2.5S CVT
QR25DE wrote:
thats wut mine looks like
theboydiddy
QR25DE wrote:If you get the factory trim plate it will look just like a factory install. Most in-dash DVD players in the car only work when the car is parked/e-brake is on. Before you buy, if this is going to affect you, do some research and find the ones that can be hacked, such as the Pioneer AVIC series.
. . .uhm. . .doesnt really look good.also i heard that the ones from manufactory only works parked with the E break on, but all you gotta do is actually disinstall one cable, and you will be able to play it while driving.
losenone
Car: AC 3.5 CVT K12
You cross 2 wires on the main power lead to a 2 pin rocker switch. Ill take pics next time im out.
headhunt3r
Car: Altima Coupe 2.5S w/ CVT
This is mine. For mine it was just one wire that I had to ground to let it watch DVD's while driving
theboydiddy
. . . it looks kind weird. =/
erick.s
Car: 2008 Altima 3.5SE Coupe
Can someone post the part number/where to buy on the factory trim piece for the nav units?
headhunt3r
Excuse the rudeness, check the FAQ!
erick.s
headhunt3r wrote:Excuse the rudeness, check the FAQ!
Maybe I'm blind, but I didn't see any part numbers or vendors listed in the FAQ. If you know where it is, why don't you post it here? In the time it took you to write your original post, you could have just put up a link.
headhunt3r
http://forums.altimas.org/zero...78369
Just for you And no, this took in relative terms, much longer than the time it took me to ask you to look in the FAQ. In case you still can't find it with the link, it's the underlined word "this". Maybe you were just keeping your eye out for a long string of characters and numbers beginning with "http"
erick.s
Thanks - I see it now
noshift
Car: 07 altima
what do you guys do as far as hiding your HU when your out? i would get a double din unit but im afraid of someone seeing it and stealing it.
headhunt3r
At the moment... nothing in terms of hiding it, but my head unit offers a 4 digit security code... if the battery is unplugged, or the deck is pulled out, then in order for the unit to function again... you have to input the code.
What I've seen in the past was that somebody used a older factory double DIN Nissan unit, strip it of its front plate, and use that as a "cover" for the aftermarket head unit. Looked pretty prime, but it'd be quite a bit of work for a budget defense. The best way is probably to get a good alarm for your car!
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
noshift wrote:what do you guys do as far as hiding your HU when your out? i would get a double din unit but im afraid of someone seeing it and stealing it.
pager alarm... worked great for me in the past... after my last incident, for some strange reason, no one wants to break into my car anymore... must have been those hollow points
duffman8189
Car: Altima Coupe
I've done a few things that have helped. Get aging tints as dark as you can get away with ,getting a sun blocker for your front winsheild and a good alarm like python or clifford,
theecoupeman
Car: 2.5 altima coupe 08
This is what mine looks like..nothing to expensive but its good for now.
