DVD Bypass
Home of the Nissan Cube forum and CubeDriver.com
jerryc41
Car: 2009 Cube SL
Installing my Pioneer AVIX 910, I followed the suggestions on this board and put in a toggle switch between the green parking brake wire and ground. Worked fine, sort of.
I could watch a DVD while I was parked in the garage, but as soon as the car got some speed, it knew it was moving (that speed sensor wire) and shut off the picture. It's the same with the Address feature of the GPS. I got a screen telling me that my parking brake connection was not right.
So, how can I enable DVD and the GPS Address feature, so they will work while the car is moving?
damian666robin
Car: 2009 nissan cube
dont kill your self guys i dont know why from beginning you dont conect the e brake wire along with the ground wire...simple and easy
stop drilling and cutting all around the dash
jerryc41
Car: 2009 Cube SL
The brake and ground wire are connected through the switch. The problem is the speed wire. With the car moving, the system defaults back to the "safe"mode - no picture, no address feature in GPS.
I don't plan to watch movies while I'm driving, but I do like to bypass systems I don't like to have more control.
Jerry
damian666robin
jerryc41 wrote:The brake and ground wire are connected through the switch. The problem is the speed wire. With the car moving, the system defaults back to the "safe"mode - no picture, no address feature in GPS.
Jerry
again with the switch
no switch guys just ad the pink or brown wire to the ground wire and that,s it i been doing like 10 stereo dvd players like that on my last 5 cars and never had an issue when i run movies while driving or even when i have extra screens thru out the whole car
terrycs
jerryc41 wrote:Installing my Pioneer AVIX 910, I followed the suggestions on this board and put in a toggle switch between the green parking brake wire and ground. Worked fine, sort of.
I thought the bypass was for the factory head unit?
jerryc41
Car: 2009 Cube SL
The parking brake wire is grounded, and the viseo works fine when the car is stopped. If the car is moving, it will not show a video. The speed sensor wire tells the computer that it is moving. There must be a step that I am missing.
Jerry
randode
switch the speed sensor wire.
jerryc41
Car: 2009 Cube SL
randode wrote:switch the speed sensor wire.
Details, please.
Jerry
randode
install a switch in the speed sensor wire. it's that simple.
jerryc41
Car: 2009 Cube SL
So the switch will kill the speed sensor and let the DVDs play. Sounds good. That'll be my next project - taking everything apart again to get at the radio.
Thanks,Jerry
randode
yup
jerryc41
Car: 2009 Cube SL
So I leave the parking brake wired grounded all the time and switch off the speed wire when I want to play a DVD or enter an address into the GPS.
What's the downside of switching off the speed wire?
Jerry
Modified by jerryc41 at 7:03 PM 2/14/2010
randode
jerryc41 wrote:So I leave the parking brake wired grounded all the time and switch off the speed wire when I want to play a DVD or enter an address into the GPS.
Jerry
the downside is it wont track your position on the navigation while the switch is off. but as soon as you switch it back on, it will work.
Return to “Cube Forum”
