Dual exhaust
takethewall
Car: 1994 300zx n/a, 1998 I30
Anyone know of any dual exhaust options available for a 98 I30? i cant find much.
thanks
MTZI30
Car: 2000 Infiniti I30t
Y
takethewall wrote:Anyone know of any dual exhaust options available for a 98 I30? i cant find much.
thanks
You'll probably need to have a custom system done. Ive never looked under a 98 i30 up close so dont know how well it would fit. May i ask why you want dual exaust? Single exaust done right will give the same amount of power if not more.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
The above is correct. You won't see any improvements from a dual system on your car than you wouldn't get with a well-designed single system.
If it's the look you're after, though, you could have a muffler shop split the exhaust after the forward muffler and then do twin tips for the dual look--this is how the "quad" exhaust on the 6th gens works (3 mufflers).
VQMatt
Car: 95 Maxima
there was 1 made by custommaxima I think, but it was waay too expensive. like $600 or $800. I dont know if they make it anymore but it wasnt even a true dual set up. just a little loop to the other side from the muffler in the stock location. To get a true dual system it would have to be completely custom and your spare tire hull would have to be modified..as in chopped to get the pipes to fit. Its a VERY tight fit and it not worth the money unless you are pushing some mad power. I wouldnt think its effective unless you are well into the other side of 300hp even then a 3in single would probably be more efficient when you factor in costs. GL THO!
takethewall
I was just going for the look. Thanks for the help. I'll look around the area for someone to help me out.
maxhopper
Car: 02 Maxima SE 6spd
Get a quote from a local exhaust shop. A true dual set up does not exist for the A32.
