kmckis1029 »
https://forums.nicoclub.com/kmckis1029-u103545.html
Tue May 22, 2012 1:06 pm
+1 red lining 3rd is about 100 mph... red lining 4th and you almost to the limiter of the car LOL
but for a quick zero to 60 you will only need to shift 1st and 2nd at about 6000+rpm... (assuming full throttle) first gear revs very quick... and 2nd gear pulls hard, if you miss a gear the car will tap brakes. Missing the second to third shift is a kill joy LOL
as you get used to the car the engine noise as it gets close to redline will be distinct and the noise of the engine when you need to shift in general will become distinct.
BUT at the drag strip i use DS mode and i do not manually shift as it will shift at redline for you. fun times!
