OK, however if i am correct, the Specs have only ONE fuel line to the rail, and no return, and it is metered at the tank. So, that being said, will there be enough fuel to feed the engine and the Nitrous if a fogger kit is used, or will it starve them both? Even adding an inline pump will seem to me to starve the engine trying to feed the nitrous, as it is metered before the new pump.Anyones thoughts on this?GTJcolon wrote:Def a wet shot shot fogger, right before the throttle body. The air and fuel atomizes and makes more safe power. You would only have to tap into the high pressure fuel line going to your fuel rail.
