Dropping in the engine this Wednesday
DjLiquid
Car: 1988 Nissan Pulsar
Im dropping in the ca18det this Wednesday. Is there anything I should do right after I get it in and test to see if it runs??
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Run it hard and then change the oil to get all the ****e out of it.
DjLiquid
I just hope my new oil restrictor holds up... It better or ill be ****ed
biosehnsucht
Everyone has a theory, and just about each can find ways to back it up as the best. Probably anything short of either revving to redline every gear immediately is fine. But yes, changing the oil + filter after you first go through whatever initial startup procedure you choose is, if not a must, a damn good idea. There will be TONS of **** in there. Then after whatever breakin period you choose also, I did ~500 miles myself..
What I did was to hold the idle at ~2000 RPM for 20 min, on recomendation of a local shop. So far so good.
Of course we were also trying to get the coolant bleeding done at the same time which was a bit complicated, but it was late December so it could have been worse.
sdtouge
Car: 1990 240sx coupe
if the motor smokes for a while in the begining check it out, but its probably fine. also, i recmoned to do the heater hoses before the engine is all the way in. thats about it.also if its rwd set the motor in the mounts, then do transmission mount, or else the motor can be crooked.
DjLiquid
It's a FWD and all the heater hoses have been changed =)
float_6969
I this a rebuild or did you just "freshen it up" and now you're dropping it in?
DjLiquid
freshened it up
zero_gripS13
Car: soon to be 95 s14 hopefully
tomorrows the big day.. everything ready???
what all u puttin in alng with the motor???any goodies
rico05
Car: 1992 RMS13 w/ CA18DET
Not sure if you did it yet, but change EVERY coolant and vac line. Some of them are very hard to get to with the motor in.
boost_boy
rico05 wrote:Not sure if you did it yet, but change EVERY coolant and vac line. Some of them are very hard to get to with the motor in.
Good advice, but the FWD CA's coolant lines and vacuum lines are easily accessible.
Dee
