Drop kit for '02 Frontier ?? Found spindles...what about the rear?
hessianben
Does anyone know of a kit or a way to get a moderate drop in the rear without sacrificing spring stiffness. I've got an add-leaf already to help with the weigh of a shell, and I like the increased rigidity. Can't do a flip- the axle's already above the leafs. Ideas?? Also, if anyone knows where to get good deals on drop spindles for the front... the only one I found so far was Belltech.Thanks!
BOOOGHAR
Car: Datsun 620
you could pull your leaf spring pack out and have them dearched at spring shop and you could go the cheap easy route and use a lowering block kit. the block kit you can get from belltech also
MrTripC
Car: 1997 d21 king cab 2.4 5-speed
Try shackles for the rear, I have had pretty good experiences with them with out sacrificing ride quality.
as for the spindles I will pm you the link because I am new here and dont know the rules about posting links in the forums
88supercharged
Car: 88 hardbody
what is the part# for the drop spindles? i searched belltech and only found drop spindles for frontiers up to 2000. i hope they fit cause i need some.thanks
PEZi
dearch the rear... lowering blocks don't work when the leaf is above the axle!!!
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
he said the axle is above the leaves. If that's the case, blocks will work.
SlamTheBoy808
Car: 2002 Nissan Frontier Crew Cab
I have a '02 Frontier Crew Cab and I cant find drop spindles for it anywhere, right now all i have for front suspension are nitro shocks. It rides pretty rough. Do you guys know where i could go for some,it seems like their impossible to find, are their other alternatives.......PLEEEEASE HELP ME!!!!!
