jakry001 wrote:with it on, my car runs like crap. and yes, i have a band new sensor. i got flat spots inbetween auto gear changes. i hit the accelerator hard and the car doesnt respond, the revs go high, but no actual response on the road...
with it off it fixes the problem by about 70%. the issue is still there, but nowhere near as bad.
mechanics are saying its a bad auto trans - but i dont beleive that is right. im sure a manual conversion will do the trick, but there needs to be a solution... something else is stuffing up...
Your TPS, leaks in plumbing, dirty afm, bad 02 sensor, etc. could be the cause of your issues. You may even want to change the sensor if you haven't done so already because its values may be out of range. Have you done a diagnostic check on your ecu? You don't need the mechanic to do that, either.
Dee
