The Stock unit from S models doesn't have the Input jack thus why I'm trashing it.Gr8dave37 wrote:I would be interested in the stock unit if it's the one with the input jack. plus it depends how much you want for it.
He already stated that he has an S model. You're looking for the HU out of an SL.Gr8dave37 wrote:I would be interested in the stock unit if it's the one with the input jack. plus it depends how much you want for it.
Noone, to the best of my knowledge, has tried this. More than likely, all of the mechanisms in the lower seat pad are all one piece, so you're talking about swapping out the whole seat. Or all of the seating surfaces if you don't want to have one mismatched seat, since the S and SL use radically different fabrics.Di Versa Fy wrote:So I noticed that my S model driver seat has the pop out for the height adjust that is standard on the SL. Does anyone know if the parts could be ordered or aquired at a junk yard to mod the S seat to be hieght adjustable?
Actually yes they are, a company makes a module that you have to wire in to the steering wheel controls which will make the stock buttons work with an aftermarket stereo.Ever Victorious wrote:Aftermarket stereos are NOT compatible with the OEM steering wheel audio controls on the Versa. There is no point in trying to refit the wheel controls if you are planning to change out the HU. SOME HU's are compatible with AFTERMARKET wheel-mounted control systems. You can look into that, if you'd like, but it's a dead end to look at the OEM unit.
The stock S radio is the absolute least sought after radio. It's got poor power output, no MP3 capability, and no aux input. Even your most basic sub-$100 aftermarket stereos are better. Honestly, it's a fancy paperweight.
why would you get rid of your side airbags for some seats that belong in a race car?reyes1212 wrote:I want to change my seats...to some nice Sparcos
Because I wouldn't mind. If I get in an accident it better not be fatal lolMr. LS wrote:
Ok, so the next thing that would be questioned... what's needed for the refit? If the controls run through the BT module (I haven't read the wiring diagrams), would it even work on a car without the convenience package?Mr. LS wrote:
People keep saying buy the SL but let's think about that for a minute.IMHungry wrote:Why didn't you just buy the SL in the first place?
Remember search is your friend.Di Versa Fy wrote:I also bought the ARM rest from Courtesy Nissan. Has anyone else done this mod? Any instructions for it?
Kinda have to agree here, I mean in the long run, you think about how much are you REALLY going to end up spending here. You have steel wheels, no cruise control, no rear seat armrest, no map lights, no center armrest console, I mean you don't get A LOT of things.IMHungry wrote:Why didn't you just buy the SL in the first place?
It's a seperate brain, your controls will send the needed signals to the brain and then transfer the signal via RF to your aftermarket stereo. NOW the catch is that this module only works on stereos which accept a remote control to use on the stereo.Ever Victorious wrote:
perhaps I should have clarified: Getting the SL Convenience package's wheel controls to work with the STOCK stereo on an SL or S.Mr. LS wrote:It's a seperate brain, your controls will send the needed signals to the brain and then transfer the signal via RF to your aftermarket stereo. NOW the catch is that this module only works on stereos which accept a remote control to use on the stereo.
I'm assuming that he has an '08 S, which means Cruise is available as an option. But the power package + cruise = $1000 on the S, so you're halfway to an SL with just those two options there. Even if he has only the power package, that's still $700 of the $2000 difference.Mr. LS wrote:Kinda have to agree here, I mean in the long run, you think about how much are you REALLY going to end up spending here. You have steel wheels, no cruise control, no rear seat armrest, no map lights, no center armrest console, I mean you don't get A LOT of things.
Like I stated in the post, you would just need to open up the HU, and make solder connections, did you bother looking at the link?Ever Victorious wrote:perhaps I should have clarified: Getting the SL Convenience package's wheel controls to work with the STOCK stereo on an SL or S.
He didn't say whether he got the S with or without the power package, but I have to assume it's with, since the S w/o power package is actually quite a rare configuration.
That said, Di Versa Fy, it still doesn't change that right now, to swap your seat to have the SL adjustment, you'd either have to be incredibly lucky and find a wrecked SL in a yard, or you'd have to buy the seat(s) from your Nissan dealer.
And unless you want to put seat covers on already, or don't mind driving around with one mismatched seat on a brand new car, you'd be talking about buying ALL seating surfaces in the car to make it match. Even a junkyard would probably charge you CLOSE to $1000 for all of the seats in a wrecked V.
Though if you're willing to spend that kind of scratch, you could always get your SL seat, then have your seats re-covered by Katzkins... we gad a forum member who paid $700 to have his SL's seats recovered in leather.
No, partially because nothing you said in your previous post mentioned anything about OEM radios... you specificially said aftermarket radio in both paragraphs.Mr. LS wrote:Like I stated in the post, you would just need to open up the HU, and make solder connections, did you bother looking at the link?
Are you sure? maybe we should do a poll on it... seriously.Ever Victorious wrote: In fact, there are more non-mechanical people here than mechanical people... which is unusual for an automotive forum and perhaps something that will shock you personally to know.
I'd take you up on it if I seriously thought that the non-mechanical people would even bother to answer the poll.illf8ed wrote:
FINALLY !!!Ever Victorious wrote:
I guess I'm wrong about everything and a jackass.
Well, I guess it wasn't that much of a secret...marleyfan wrote:
FINALLY !!!
jk EV
If you went with the S you don't have the steering wheel audio controls. If you've found a way to install those, i would love to know. That's what I wish I had (and an iKey) most.Di Versa Fy wrote: so for me all I want from the SL is the ... audio controls.
The stereo I bought for $200 has the ability to use factory wheel controls.
There's quite a difference in in the transmissions. For some of us, the CVT was a major selling point.Di Versa Fy wrote:SL = $17405 MSRP S = $15900 MSRP
Both Automatics
For that matter, if you went for the SL, you still don't have them unless you also got the convenience package.Great White Versa wrote:
*dies... again*Ever Victorious wrote:I guess I'm wrong about everything and a jackass.
Okay, I'm bitting...S Hatch (manual)- Splash guards- Power package- ABS- Cruise Control- $14,900Di Versa Fy wrote:SL = $17405 MSRP S = $15900 MSRP
Both Automatics
Both with same options added. (Floor Mats, Spoiler, ABS, Splash Guards) (and cruise on S)
I could care less about wheels and the rear cupholders/armrest, so for me all I want from the SL is the seat adjust, center armrest, and audio controls.The stereo I bought for $200 has the ability to use factory wheel controls. The seat I can see would be a problem now that I know more but I can live without. The armrest arrived today. So for essentially $400 I've got my bit of SL bling that I need. So enough already with the should have gotten an SL crap.
