NolimitZ32 wrote:If you have an offset socket try getting at it from under the car and the back/bottom side of the socket, you'll have the fulcrum closer to the sensor itself and would be able to put more force on it.
Have you removed the drivers side O2 from below before? I can get access to a lift to do it. After half attempting it from the top, I am convinced to try and go from underneath. Does this require dropping the exhaust?
PS. The O2 sensor nut stripped from corrosion on the passenger side. I soaked it in pb blaster and attempted to clean the threads. While cleaning the threads the whole nut came loose and I just replaced it. I intend to replace both pieces (o2 sensor nut and o2 sensor) on the other side if possible and use plenty anti-sieze.
