DPF cleaning. 2011 M30d (Diesel Particulate Filter)
mikewill53
Car: 2011 Infiniti M30d
Hi
Does anyone have an article on how to clean the DPF using the moli method
Thanks in advance
Mike
Reason: Edit title
EdBwoy
If this is in reference to a diesel, remember to post it in the 2011+ model section.
You are more likely to come across other members with your vehicle there.
EdBwoy wrote:
Fri Apr 10, 2020 7:56 pm
mikewill53 wrote:
Fri Apr 10, 2020 11:22 am
Hi
Thanks for the replies, my cars an M30D 2011.. but you don't seem to have them in the US so I never know what forum to use ...
This is the most correct forum then. I think it would be less confusing if you called it a 2011 Infiniti M...or just refer to it as the M30d, we'll figure it out from there, but as you might have noticed, we have more similarities than differences.
Ilya
Moving this to the Y51 section.
mikewill53
Ok thanks for moving it
Diggi
Car: 2012 Infiniti M30d
where is the Y51 section?
Bellresa
Car: non
If you're interested in trying the moli method yourself, there are some resources available online that may be helpful. I would recommend doing some research to ensure that you have a good understanding of the process before attempting it.
Bellresa
Car: non
BTW, While I don't have a specific article on hand about the moli method for cleaning a DPF, I can share with you some general information about the topic. One thing you may want to consider is using a professional cleaning service, such as Ford DPF Cleaning Services or Freightliner DPF Cleaning Services. They have specialized equipment and expertise in this area, which can help ensure that the cleaning is done properly and effectively. That being said, if you're interested in trying the moli method yourself, there are some resources available online that may be helpful. I would recommend doing some research to ensure that you have a good understanding of the process before attempting it.
