AppleBonker »
https://forums.nicoclub.com/applebonker-u101518.html
Thu Apr 23, 2009 2:21 pm
Sorry, been crazy busy lately. There is a rubber grommet that can easily be removed and put back on. Open the door and pull it off so that the hole in the car and door are visible. I'm pretty sure I dropped some twine or something into the car from the hole (put in in the opening where the door closes and drop it towards where the driver's feet would be). Then, tie it to your speaker cable (use some tape - I used electrical - so it doesn't snag) and pull the cable through. Then fish it through the rubber tubing. You can then replace the grommet on the body of the car. Next, send it into the door and you should be able to easily grab it through the speaker opening (obviously once you remove the door panel and the speaker in the door). Let me know if you have any problems or need further explanation.
