does anyone know the compression ranges?
reggiebrown40
Car: 2018 Infiniti Q60 Red Sport
2011 Infiniti M56x - Dead
Need to know the acceptable cylinder compression (psi) ranges for an M56. Thanks in advance.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
For an '11 it's 242 psi standard, 206 minimum, 14 maximum difference between high and low (measurements at 200 cranking RPM). You can find compression specs for any particular model on the first page of "Service Data and Specifications" at the bottom of the "Engine Mechanical" section of the FSM. For the '11 VK56 M it's EM-300 here:
https://www.nicoclub.com/service-manual ... 1%2FEM.pdf
reggiebrown40
VStar650CL wrote:
Sun Oct 02, 2022 5:43 am
Thanks!
reggiebrown40
Can you run a compression test with no manifold? What about a crack in the block? What would the result be? Building a case against a repair shop.
VStar650CL
Technical Expert
reggiebrown40 wrote:
Fri Nov 11, 2022 12:34 pm
Yes.
Depending where the crack is, it may or may not effect compression. Most cracks which affect compression are in a cylinder head and not the block.
reggiebrown40
VStar650CL wrote:
Fri Nov 11, 2022 1:05 pm
Yes.
Like this? Hard to see from the screen shot, but this is the left side of the engine block before spark plug #1.
VStar650CL
Technical Expert
I don't know Infiniti like I know Nissan, but that looks to be the rear timing cover and not the block.
reggiebrown40
Thanks. Appreciate the help.
