Yep. It's the worlds greatest misunderstanding.Sentientbydesign wrote:So you mean to tell me that a 165mm tire with 35 PSI will have the same contact patch as 285 with 35 PSI?
I might be missing something crucial here, but I find that hard to believe.
The gain in traction of the tire is involved with dynamics. There is a point where additional pressure on the tire does not yield a 1:1 response in grip. This has alot to do with the tires load index.Sentientbydesign wrote:If this were true, then the benefit of wider tires is negligible within a tires operating pressure.
It would say that a 185mm tire with 35 PSI should have the same contact patch as a 355 tire with 35 PSI. As such, there is not reason to go for wider tires in order to improve traction.
As long as the tread didn't wrinkle, thereby lifting a portion of the adjacent tread, then the friction between the two widths should be very close.
The reduction in hydro-planing is because of the tread, not the wider tire. A wider tire is worse in the wet / snow. This is because the patch is wider, giving less time for the tread to evacuate water.Sentientbydesign wrote:Interesting. So the direction that all of these car manufacturers are going with wider tires is unecessary and is only for marketing/aesthetic.
My experience with wider tires yielded me better traction and less hydro-planing. I'm having a hard time digesting this information.
Also remember that while the area may be the same, shape effects things too.Sentientbydesign wrote:Interesting. So the direction that all of these car manufacturers are going with wider tires is unecessary and is only for marketing/aesthetic.
Good thing right?Nismo_Freak wrote:Ah, another learned individual from the Milliken and Milliken school.
Part of the industry does, but there are many companies that produce quality components as well.Q45tech wrote:The aftermarket industry DEPENDS on the typical buyer not understanding even high school physics.
Is that a manditory class in HS?Q45tech wrote:The aftermarket industry DEPENDS on the typical buyer not understanding even high school physics.
Balloon theory is a gross generalization. It's the exact same as power vs. weight in that it does not address the details within the actual empirical usage of the item.rcabrita wrote:When comparing two diffrent width tires with the same construction, materials, side wall profile and diameter.EX 200mm VS 315mm
I will be honest, I do not know what hitch or slip angle. But after I do some searching I am sure I will understand!Nismo_Freak wrote:For what it's worth, here's a tire load vs. slip angle test. See the linear and un-linear relationships.
If you want to learn the easy way, get a book called Race Car Vehicle Dynamics. It's $100, but it's value is worth 10-fold.rcabrita wrote:I will be honest, I do not know what hitch or slip angle. But after I do some searching I am sure I will understand!
Thanks allot! I really do appreciate your response.
Pretty much everything else (economics, business,psychology...)Sentientbydesign wrote:What was your previous major?
Hahaha. I know the feeling. If money weren't an issue, I'd pursue a Masters in Mathematics, a PhD in Psychiatry, and a BFA in Graphic/Multimedia design.Red coupe wrote:Pretty much everything else (economics, business,psychology...)
Didn't really know what I was looking for, just knew I liked how things worked (i.e. how economy works, how buisness worked, how peoples brains worked...and how race car works) Those were all at the JC level though, and none but econ went past an intro class....even econ I only had a few classes in.
When I talked to the councilor towards the end of my JC period she was amazed how many units I had, and that I hadn't taken more physics... I spent a few years studying everything from music theory to engine rebuilding and emissions controls.
I like what I am doing now though
