I can't say the $472 I made as a guitarist in a DC area metal band was worth my hearing loss... Wait, I sure as &^%$ can say that!!
Not only do I have a legit excuse for not hearing my better half telling me to do something, but I can buy relatively cheap speakers now that I can afford the other kinds
Yeah, kinda sucks with the ringing all the time, but one gets use to it.
For me, I find the separation and dynamic range to be what I tune in to. I have pretty pronounced loss at different ranges, so speaker bias is more a matter of my ears than the speakers. Back when I was younger I would have tossed the Bose first thing. I actually just opened a box from 90's storage filled with NIB Jensen speakers
Foam is shot on nearly all of them (4 pairs too!).
Forcing the system to use the 5.1 amp is so noticeably better cause yeah, the two channel amp is weak for sure and has no eq control.
I'm pretty sure I've got a bad (?) right rear door speaker as I get cracking occasionally at volume - although it may just be interference from the active noise reduction system, which I believe uses those speakers as well. Did you work on the rear door speakers? Is there anything special about them?
