DIY fuel rail flush!!!!!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Alright.... I did a little research here, and I wanna know what you guys think......
I got on 3M's website, and apparently they sell stuff to do fuel rail flushes......
Take a look at this site.......Click here for 3M
Anyway, they basically tell you what you need......
I compiled this list of stuff..... These are all buyer part numbers off 3M's website
08920- Adaptor08828- Adaptor cleaning hose08955- 120 PSI solvent can08828- Fuel regulator valve, extension hose, etc.......
Also it seems as if they make a KIT for our car, PN: 08816, but I cant make any confirmations on this.....
This seems as if we can get all these things for under 200, we only have to do 2 flushes and it has already paid for itself..... This also seems good as we can adjust the fuel pressure as necessary..... Finally, we could use it on ANY car we needed, all you gotta do is go Here and it will tell you what adaptors and stuff you need.......
Let me know what you think!!!!
elwesso
2007 BMW M Coupe
I also forgot to mention..... They sell kits of all different kinds of adaptors, but they give a number so you can buy individual adaptors so you dont have to buy the whole thing......
Also, then we need to figure out where to get this stuff, as 3M doesnt sell it online......
elwesso
2007 BMW M Coupe
Bump... let me know what you think this could be golden!!!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I wouldn't associate "golden" and "flush" in the same sentence. :pface
The Nissan dealership where I had my Q45 Envirolutioned uses the 3M injector rail flush.
elwesso
2007 BMW M Coupe
Would you know of a place online where I could look into the pricing of this stuff......
Id say an average fuel rail flush costs 80-100...... I vaguely remember seeing the hose kit thing for like $25, and the regulator for not much more.... Id assume the adapter would be $1 or so (its just a fitting), and the solvent would be like $30....... Even if it comes to something like $100 for all the stuff, you still save yourself tons of money......
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
and assume tons of liability if it blows up in your face.__________________Brian1995 Q45 & Q45t & 2000 Q45
Discover the power of the button!
elwesso
2007 BMW M Coupe
This process isnt that big of a deal, so Id go for it!
VenCountyQ
http://www.handsontools.com/st...=8206 has a basic 3M kit for $229
elwesso
2007 BMW M Coupe
Hmmm........ that sorta puts a damper on things.....
Id be interested in going in half or a 3rd with NICO members!!! It would make a great value!
DAEDALUS
Car: 1990 Infiniti Q45
My preference is for a kit that uses a shop air supply for pressure, because then you don't limit yourself to one brand of cleaner, that has a certain pressure, and with a certain kind of high-pressure connection. I haven't looked into it quite enough yet, but with a little bit of jury-rigging, such a kit should be able to be modified to attach to a spray nozzle for atomizing injector cleaner into the intake.
elwesso
2007 BMW M Coupe
Thats a good point..... Ill start browsing the web for this sort of thing.....
Question is... Where do you get the solvents???
Q451990
I called my local BG rep and the price quoted was in the $250-300 range for the BG flush kit. This is supplied by compressed air. I'll probably buy one soon...
Heath
Q45tech
Since the fuel injectors see 34 psi most often and 43 psi only at WOT. The ability to vary and increase pressure to 50-55 psi during PART of the process is invaluable.
The difference in flow is 25% faster at 55 psi so don't hurry the process too much..........11 ounces can flow fast with higher than 650-750 idle rpm and higher pressures.
The flush kit also has the fogger nozzle for cleaning the plenum and runners.
natsoundup
Heath...you buy the kit and I'll come down and pay you to do mine....
Lee
elwesso
2007 BMW M Coupe
Maybe we could get some guys to go in like 3 or 4 ways for the midwest.....
Anyone???
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
How about just pouring some solution into the fuel filter and running it. Wouldn't this accomplish the same thing?
DAEDALUS
At first, but the solution would get diluted with gas as the engine ran. More importantly, you'll get at most 43 psi by disconnecting the regulator vacuum; the procedure is best when the rail pressure is elevated.
reggiegsd
Car: '94 Q, '73 240Z
I like the injector flush. Its a great way to break your engine mounts.
Q45denver
1990 Infiniti Q45
Has anyone tried the Run-Rite kit? $69 plus shipping. They also do the service at Pep Boys using the kit for $89. Would pay for itself with one use. I don't think I'd trust Pep Boys with my car.
http://www.sensiblewebsolution...3.130
http://www.usalubrications.com/run-rite.html
elwesso
2007 BMW M Coupe
I had a cadillac technician recommend the run rite kit to me..... Might not be a bad idea looking into that!
Q451990
Looks like a pressurized canister... can't tell for sure though. I'd buy it and use the BG flush... if it'll work that way.
Heath
