Covering the ambient light sensors will cause the navigation display to load in "night modem". In the M you can just press the day/night button to switch it back. For EX specific answers see the EX forum.LochDhueDude wrote:I see this thread may have gone dead, but...
Clark Howard (WSB in Atlanta) regularly cites a study that supports a 20% reduction in accident incidents when vehicles have their headlights on. I am used to vehicles that have an auto headlight system that will run the headlights no matter whether it's light or dark outside. The lights come on when you crank the vehicle, then turn off after a set interval after the vehicle is turned off. I understand that on my 2011 EX35 there are one or two sensors that determine whether the lights are on in "Auto" mode, depending on the ambient light. Does anyone know if it is possible to cover those sensors to enable the auto headlight function regardless of day or night? Are the sensors on my EX located on the left and right sides of my center windshield defroster vents? Would covering the sensors (wherever the darn things are) interfere with any other functions? Please PM me if you reply to this. Others may have some interest, but I might miss out on a reply...
Thanks!
Mike
Do you normally drive with the switch in the "Parking" position? If so yes, the headlight 12v will be better. I don't think I ever use "Parking" except for maybe when I am stationary, so no DRL is ideal.jtsull wrote:Done. Now for the wiring so when the highlights are on, the DRLs are off.
I'm thinking the highlight 12V hot is a better connection for this. If the marker light is used to determine if the headlights are on then there will be no front lights other than side markers and rear lights when the light switch is in the "parking" position. Looks like a nightmare to get at that wiring....
