slownslurious wrote:everyone is so negative! I bet none of you guys have ever even used a VPC. I've seen a very high HP'd supra using one and it was very driveable.
um i have used it, i had a VPC and GCC that came with my CA clip, and i ended up using none of the goodies that came on my clip, i installed it stock, i tried running the vpc, and couldnt get it to run right, a/f was all over the place, and the gcc i had was all but worthless. i finally plugged in the maf, and my car ran fine. got rid of the vpc and the gcc for 175$. the only reason i could see to run one is for the bling factor or if you are pushing more than any maf availiable will allow. which i find hard considering the options availiable. if you really are worried about maf restriction, use a ford lightning maf, i can fit my arm through it and we have a 650whp b13 sentra at the shop running a tuned stock ecu and a lightning maf... and a big *** turbo, with no problems. you might say, well a map system is better, well, then get a standalone that is designed to use one, its less headaches than using some ancient converter.
