distributor coil or module
michael_grigoras
Car: 1991 nissan 240sx
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
need help car turns over i tested the coil and its fine but i cant test the distributer or power module no spark whatsoever :confused:
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Post is vague, but the factory service manual has test procedures.
the-ultimate-sticky-read-before-posting ... 41882.html
costa_rican13
Car: 1993 s13 coupe
same problem with me, but i get spark, and nothing. not sure if it the coil or module. how do you test the coil??
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
Ok so all three work still no spark but the ecu isn't fried thank god so not sure what it is :/ gonna check the wires tommorow maybe bad connection
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
narrowed it down to 2 problems its either wires that connect to the distributor or the crank angle sensor
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
turned out to be the crank angle sensor replaced it just gotta put distributor in correct to avoid it getting off timing i suck at timing lol
costa_rican13
Car: 1993 s13 coupe
where'd you buy the crank angle sensor??!!
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
the crank angle sensor is actually inside the distributor when you take the cap off and the rotor lol
costa_rican13
Car: 1993 s13 coupe
i know, but you said you replaced the crank angle sensor, so where did you buy the crank angle sensor from??
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
i just went to autozone and oredered it lol
costa_rican13
Car: 1993 s13 coupe
part number?? i went there and couldnt find it.
costa_rican13
Car: 1993 s13 coupe
never mind you have a single slammer. i have the de.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
nope got a de
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
did and engine swap from the single to the de a while ago
costa_rican13
Car: 1993 s13 coupe
You got a part number? Because I can't find it at autozone.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
i would just buy new distributor
