websfear »
https://forums.nicoclub.com/websfear-u76038.html
Sat Mar 29, 2008 3:15 pm
BTW, the reason I am considering disconnecting the battery is...
1. I am planning to run #8 or #6 wires from the battery through the firewall. The best way I can see of doing this is to remove the air intake parts. Per TSM, step number 2 is removing the battery.
2. Mounting some electronics under the passenger seat. I will need to remove the seat, and again the TSM says to disconnect the battery (I assume so the side airbag doesn't deploy!
