Patarach wrote:when you d/c the maf It will not rev past 2500rpm its like a failsafe.
what rpm does you car idle at and does it idle rough?
try d/c and plugging the line to your FPR and seeing if it will run longer
Idles between 1.5 and 2k.
Will do.
What motor is this? KA?
As Patarach said, when you disconnect the maf it's like a "limp mode," and you can't go past 2500RPM.
Has the car always done this? Check the maf wiring, grounds, etc.
Yes, it's a KA. It's been like this since I bought it a few weeks ago. Gonna check the wiring and grounds.
