J30 is my first car, so when the battery stop taking charge, and i was told it was the alternator belt, I figured I would just replace, so I got the belt and jacked up the car, looked under it, found the alternator belt, the threads of the belt were torn so i was pretty sure i had the right culprit.
Unfortuantly, i have no idea how to change the belt,
I found this:
zerothread/297616
and thought the tensioner was the long screw behind the pulley of the second belt, I loosened that up and thought i was in success because the belt comes off easily now. I saw a similar system for the first smaller belt on the upper passenger side (battery side, left side if I amm looking a the car, sorry my terminology is poor with this stuff) and i tried to loosen that the same way, but nothing loosened, I did the same with the long screw in the system under the alternator for the third belt (which i think is the one I am supposed to replace) and still, nothing loosens like the second belt did.
Now I am reading that the tensioner is not the screw at all, but the bolt on the pulley? I'm not sure, and i am also hearing something about having to recalibrate my stuff, did i make a big mistake? If someone has a picture of what im supposed to turn I would appreciate it!
Thanks in advance!
