Woody64 wrote:For the defroster, I am assuming the vent was open, and not closed ( we have all missed the simple things before).
On other cars I have owned, the rear wiper fluid always took a while to travel from the front reservoir. Did you hold it down for a while, 30 seconds perhaps to allow the pressure to push it back through? If so I would agree with the previous post, something is clogged, or possibly, just look under the hood and make sure the little washer fluid hose is attached to the reservoir. Hope this helps...
I did not realize the defroster vents could be opened or closed. I thought they were always open?
I don't recall how long I held the lever down - but I will pay attention tomorrow when I attempt the "needle" solution and make sure I give it enough time. Thanks for the suggestion.
