Dee, need ya help.
campground man
Car: 1990 Ca18det B12 Sentra
I need some info on the b12 rear disc conversion, I couldn't find much of any specifics on it.
You got an email addy? You can remove this post since it's non-CA related also - I seen you online and knew no other way to contact you.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
hows your car rolling? still running well I hope?
did you get the loose ends all tied up?
mazikowski
Car: 2013 Subaru BRZ Ltd 6MT, 1984 CA20E 200sx, 1981 L28E 280ZX
Sorry to do a little thread jacking, but i'm interested in this too as the KN13 chassis shares so much in common with the B12 as far as suspension is concerned. Would the B12 rear disc hubs properly fit the KN13?
boost_boy
Both of you guys got mail, but please take heed to the disclaimer. PLEASE (for the sake of god), DO NOT share those contents with anyone else wanting to duplicate this feat. It's too dangerous and if you don't know what you're doing, leave it alone as well. As a fellow enthusiast, I'm trying to help. As a friend, I'm asking you guys to take heed to what I've said as serious injury will result if done incorrectly. Some things I don't share, but I am trying to help because you are FWD and are at a disadvantage with little to no info on something I've perfected.
Thanks in advance, Dee
campground man
Thanks for the info, Dee. After reading I don't know certainly if it's worth the trouble, but it'd sure look sweet with some painted calipers when I get the new rims.
Gabby,
I'm still trying to get some loose ends tied up. The car is painted, and i've gotten a replacement rear bumper for the one that was taken by the garbage men. I already had another front bumper, I just gotta wait for the skirt piece to arrive from Germany.
Hopefully within the next week or two I'll have all the paint work done. The first thing that will be done (before the bumper skirt is installed) will be a new front mount intercooler and piping. This will all fit right behind the factory air dam on the euro front skirt.
There is still a bit of running problems with the engine, firstly I need to replace a couple of bad sensors, then get it tuned a little better. It runs a little rough idle and you have to give gas to keep it running when cold - I'm sure it won't be too hard to figure out.
The engine pretty much will remain stock with the exception of the intercooler and a max of 10 p.s.i.
I will be replacing the clutch and installing phantom grip also.
Here is the latest pic -
boost_boy
campground man wrote:Thanks for the info, Dee. After reading I don't know certainly if it's worth the trouble, but it'd sure look sweet with some painted calipers when I get the new rims.
Gabby,
What do yo have for suspension? If you don't have one, I can tighten you with a decent suspension that I've used for a bunch of years (KYB Gr2s and Intrax). I'll provide you with brand new struts if you're interested. Hook-up the big hose off the intake manifold (the one that tees off to the AIV) to your intercooler piping and that should take care of your cold start issues.
Dee
campground man
The suspension is basically stock with the exception of the sway bars from a Pulsar in front and rear. And a Pulsar GTI strut tower brace.
Struts are the advance auto special, but I don't intend on replacing them until they are wore out.
Before I did this tear down (and even before the Pulsar sways) I was satisfied with the handling - even amazed how much better it was.
There is one tidbit of info I do need to know though. I plan on buying some Kosei K-1's. I am currently running 50's on stock Saturn wheels.
#1 Will those tires fit on a 7 inch rim?
#2 Can I use a 7 inch wide rim on this car without rubbing the wheel wells/struts?
#3 What would be the specs I'd need to give a wheel dealer for the offsets etc so that I would not hit my rear struts or rub my wheel wells?
boost_boy
campground man wrote:The suspension is basically stock with the exception of the sway bars from a Pulsar in front and rear. And a Pulsar GTI strut tower brace.
Wheel specs will need to be very close to that of the 1991-99 Nissan Sentra SE-R and the SE-Ls. Those are 15's, but the off set is perfect. I think they are 15x7 or 15-6.5s. Check to make sure.
Dee
