decided on KA-T need opinions
daniel240
Car: cars/motocross
ok ive finally made up my mind to turbo my ka. im tired of putting expensive bolt ons in with little hp gains. i dont want to spend a lot so it will definately be custom. my motor has 85k on it so i think it should be ok. all i want to run is like 6 or 7 psi. i dont know a whole lot about peicing a turbo together so help me out. i know the basic parts i need but will i need to upgrade fuel pump and injectors at that low boost. also, do i need to change the ecu? what size turbo would be good for this setup. also is it hard to make a custom manifold and how would i go about doing so. also, roughly, about how much hp would this give me with my mods? -thanks-
Structure240sx
search but ill getu started since u have nice car
upgraded fuel pump and fmu 6 heat range spark plugs gapped to about .030stock ecu is finet3/t4 would be good quick spool but will give u room to turn up the boostget a jgs manifold and bring it to exhuast shop to weldabout 230+rwhp
Structure240sx
also if u dont know alot about puttin together a kit u might want to look into buyin a kit. greddy's is kinda cheap no intercooler but u can run 6psi no prob and no one will be able to tell ur car is turbo from the outside
daniel240
Car: cars/motocross
i dont want to spend the money on the kit. i want to try and keep it under $1500, so im going to probably just peice togther used parts. find and intercooler and other parts at a junkyard and probably buy the turbo and manifold online. this may be a stupid question but what is a fmu? also were do i get that jgs manifold from? is that like a universal manifold or something? i heard people making turbo manifolds out of their header. also, were would be a good place to look for a used or cheap turbo? -thanks.
Structure240sx
fmu -fuel management unit it increases fuel pressure under boost to force more fuel through the injectors
teh jgs manifold i thins is jgycustoms.com- its not universal its the flange and runners closed off. u then have a flange to weld on whereever u want the turbo to go then port it out.
cheapturbo.com has good prices or look around herea guy on the forums is sellin a t3/04 right now i think
Drift Machine
Car: 1991 KA-T 240sx
Quote »teh jgs manifold i thins is jgycustoms.com- its not universal its the flange and runners closed off. u then have a flange to weld on whereever u want the turbo to go then port it out. [/quote]
Structure means jgstools.com
Structure240sx
there you go sorry
Structure240sx
that was jgycustoms.com i think i was thinkin of they are into SR's dont go there please
daniel240
Car: cars/motocross
ok where can i get the flange to weld onto the jgs manifold? and do i really need an upgraded fmu, if so how much is that? thanks for the help.
Structure240sx
the flange will come with the manifold from what i know. dont skimp out on fuel its not worth it. im selling my fmu with 300mi on it for $100. anywhere else will be like $200. i jsut want to get rid of it. wiht a walbro pump i was able to hit 10psi with it safely but i dont recomed it, thats kinda pushing it.
daniel240
Car: cars/motocross
where does the fmu go. i may want to buy it from you here soon. so the fmu is all i need as far as fuel system for up to 7psi? also ive been reading, would i need to retard the timing for this setup?
Structure240sx
u mount it to the firewall or like i did to the strut tower with a self tapping screw on the left side of the engine bay. then u put the return fuel into one side of it and the supplied fuel line from the fuel rail to the fmu. i would get a walbro 255lph fuel pump also. other people say u dont need it but why take the chance for $100?
daniel240
Car: cars/motocross
would a 300zx tt fuel pump work also? so your saying with the fmu and better fuel pump i will be ok? i dont plan on running over 7psi. also do you know if i need to change the timing or not?
well heres the list as of now:
-T3/To4e turbo-jgs manifold-junkyard IC and custom piping-custom downpipe-fmu -fuel pump???-wastegate???
let me know if this looks ok for up to 7psi.
Structure240sx
300zx will work but i would jsut pay a lil bmore for a brand new walbro. ull be fine with that fuel setup. but now i might be holdin onto my fmu for another month or two tops. as soon as winter hits the car is goin in the garage then gettin an ecu retune
daniel240
Car: cars/motocross
hey structure, let me know when you want to sell the fmu, ill buy it if you want to sell it here soon because i want to do this over winter break because im in school so let me know, my email is: [email protected]
WongFeiHung
...and blow-off valve?
WongFeiHung
What is a good way to control boost on a budget system like this?
andrave
Car: 1989 Nissan 240SX Coupe
some say MBC but they aren't the most reliable, I'd get a used EVC or profec or something for maybe 100-150 bucks.
daniel240
Car: cars/motocross
yea sorry i forgot, im getting a 1st gen. dsm bov.heres the updated list:
-T3/To4e turbo-jgs tools or custom manifold-tial 35mm wastegate-1st gen. dsm bov-junkyard IC and custom piping-walbro 255 fuel pump-fmu
i need an adjustable wastegate since im not getting a boost controller. is this one adjustable?
andrave
adjustable by putting diff. springs in it, yes.I'd be a BC, even an MBC would be better than just wastegate control, I think.Also, which IC are you planning on using?
WongFeiHung
If you use a low boost spring....and then later on get a boost controller...do you keep the same spring in the wastegate??
andrave
yeah. you cant ever go lower than your wastegate spring but you can always guy higher with a boost controller.
s86d
Car: autocross, backroad racing, and working on 240's
this thread is great you guys kept it simple. I now have a good idea on what to do. thanx.
daniel240
Car: cars/motocross
yea, ive learned so much from this thread. -not sure on the IC, just whatever i find at the junkyard, about any IC will work, it will be all custom and ill have a muffler shop bend the pipes for me.
-does anyone know what psi i would run with a tial 35mm wastegate? or are they all different, because i may be buying one in a day. also how would i be able to tell what psi i am running, should i get a boost gauge?
-also, would i need injectors along with my upgraded fuel pump and fmu? i was also wondering if bigger injectors and larger fuel pump would be a good combo, without the fmu?
andrave
1) no, they are available with springs anywhere from 4 psi up to I've seen 12.
2) yes, boost gauge. Get one! Even if you only get a cheap one, they are invaluable. If you get one of the more expensive ones you might even get a "high boost warning" feature, which would be cool.
3)You will need a bigger fuel pump if you are going for bigger injectors. If you stick with like 190 or so hp you can probably keep the stock setup.
dvd
this is interesting...maybe after you get your whole kit together, maybe do a small write up? i'm plannin on turboing ka.
daniel240
Car: cars/motocross
dvd wrote:this is interesting...maybe after you get your whole kit together, maybe do a small write up? i'm plannin on turboing ka.
will do. im planning on doing the whole thing over my christmas break or sooner if possible.
daniel240
Car: cars/motocross
what about using just a walbro 255 f/p and bigger injectors without the fmu, would this work for 7psi? or should i just get the fmu and f/p?
Structure240sx
u would have to get the bigger injectors tuned somehow. SR 370cc inectors and an safc would be a very good fuel system i think for 7psi that can take u to 10psi
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Structure240sx wrote:370cc inectors and an safc would be a very good fuel system i think for 7psi that can take u to 10psi
My 370s are maxed out (100% duty cycle) at only 8psi from a T3/T04E. They may be able to support 10psi from a T3...but it's not an absolute #.
Basically, 370s will get you to ~250rwhp...which may be 8psi, may be 11psi - Depends on the turbo.
Later - Brian
