decided on KA-T need opinions
dvd
hrmm then again u have a s14 and i have a 89 s13 =[ . ahh i must learn more about each parts thats required. =\
Structure240sx
orion are they maxed out at 8psi with the hacked maf or jwt ecu or both? ill be puttin in my nismo 740cc's over the winter so im jsut curious about ur setup
daniel240
Car: cars/motocross
yea i think im going to stick with the walbro f/p and the fmu from you structure. thanks
rco8786
daniel our setups are almost identical...except im just going t3 w/ an internal wastegate...hoping for 225whp or so at 7psi
daniel240
Car: cars/motocross
yea thats my plan, so far i have a t3/t04e turbo from XS, a walbro 255 f/p and a custom manifold. im waiting on an fmu and i still need to get a wastegate, bov, and manual boost controller, and oil lines. im getting the IC from a junkyard hopefully this week. i should be done with the project by the end of this year, if not sooner. i cant wait.
s86d
Car: autocross, backroad racing, and working on 240's
hey daniel it looks like the turbo race is on between you and me. ( I dont really mean that proceed safely ) I have the flange manifold walbro pump 2 spare motors ( be nice to all the kiddies doing sr swaps they give stuff away :D ) And im looking for my turbo right now...
daniel240
Car: cars/motocross
i got mineoff of ebay for $385 shipped. its a brand new t3/t04e from xs. theres so many on there, just make sure you get one from someone with a high rating or a company.
s86d
what was the ar for your turboI was told for the t3/4 to go rather large??? and im looking at ebay i'll let ya know what i find
Nathan
Didn't daniel score the 50 trim with .63 ar turbine? If so that's a good one to look for :) the 60 trim is nice too for higher boost.
daniel240
Car: cars/motocross
yea thats the one i got.
Chingon
Car: 1991 and 1992 hatchbacks
I'm not highjacking or anything, but I'm wondering if there are comparable turbines from car manufacturers to that of the T3/T04E. Also, what's the difference between the T3/T04E and the t3/t4 turbines. Is just that I see a lot of t3/t4 in ebay for real cheap. I'm also trying to do a "custom" setup and am wondering if the following units would be good for say...240~250hp?
http://cgi.ebay.com/ebaymotors...73954
I think these are the specs for that particular car T5-R 20V 5cyl 2.3L
1996 850 R
Intercooler
186 kW 5,400
240 hp
330Man, 300Auto, 2400
242 ft.Ib
8.5:1
9.6 psi 10.9 overboost
LH Motronic 4.3
0-100 km/h 7.4 sec Man
**ON a side note..Research your intercoolers more throughoutly. I've read that an oversized ic will only hurt you if you are not pushing enough air through it. (correct me if wrong.)
hannibal
Car: Red Line to Glenmont
T3/T04B and T3/T04E are the 2 versions of a T3/T4 turbo.I think that turbo from the Volvo is on the small side, but may work for you (240 hp max). I dont know much about Mitsubishi turbos, maybe some DSM guys could give you some help.
Jay
stilesg57
:: orion :: wrote:Basically, 370s will get you to ~250rwhp...which may be 8psi, may be 11psi - Depends on the turbo.
Later - Brian
is this with or without an fmu? Is this just 370's, a fuel control device (emanage or s-afc), and a walbro?
BTW I'm convinced a small 16g off a dsm would absolutely ROCK on a KA24. I'm almost tempted to get a mitsu flange with my jgs manifold and get either the small 16g or 18g (more likely, I think it's matched better).
IGTBUS
Car: If I can eat it, drive it, or **** it, I dont want it.
Maybe you should try the starter kit at Realnissan.com Its only 1900 and everything that you need to get you started, and it includes that manifold that has the flange that lets you upgrade to external wastegate later on.
MarkEmark
Car: fully-built '95 240sx KA-T
Structure240sx wrote:search but ill getu started since u have nice car
upgraded fuel pump and fmu 6 heat range spark plugs gapped to about .030stock ecu is finet3/t4 would be good quick spool but will give u room to turn up the boostget a jgs manifold and bring it to exhuast shop to weldabout 230+rwhp
Not to hijack the thread, but....Why does everyone change to colder plugs? I know the concept behind it, but my Bosch Platinum +4's have seen about 1000 miles of boost and look perfect, just like they did before I turbocharged it...And my timing is the same as stock---never pings at 9 psi, I run it with 94 octane and have alc injection though....
Structure240sx
i switched just cuz i from what everyone says. my 5 heat range's were fine when i pulled them thinkin about it. the main problem was that they were gapped top far. something like .044. oncei put in the 6's at .035 everything was fine
canadians14
does anyone have a XS engineering turbo kit ... they don't include a fuel pump and run about 7psi .... was anyone having problems with that ?
MarkEmark
The Bosch's are platinum, so they don't need gap adjustment. I'm not running an upgraded fuel pump, and I've never had a fuel delivery issue...i'm actually running a bit rich (better safe than sorry).
As I said...she runs well...just some backfiring
PS--The new ACT clutch/Fidanza flywheel kick ***---they made a damn big difference!
andrave
Car: 1989 Nissan 240SX Coupe
you should probably always check the gaps, even on pregapped plugs, cause often times they are off, or they can fall in the truck or whatever and get off.its not a bad idea, doesn't take too much time...
