If your cam gears are leaking, you should buy a new belt and do the whole timing belt surgery at the same time. Instructions are in the Haynes manual or on several different websites on the internet. z31.com, xenonz31.com, etc.NissanFairladyZ32 wrote:How do i change the cam seals without messing up the timing ?
should i just mark where the cam gears are lined up as of now (with the belt on) then take old belt of, gears off, replace seals, gears back on new belt on, re-align cam gears and be done with it ?
Dont you have to pull the crank pully off to change the timing belt ?
i have the shop manual i just dont understand how to not mess up the timing when changing the cam seals
